Can anyone tell me why my jag engine sometimes
surges and hesitates repeatedly at around 50 miles per hour?
I had the throttle cleaned but it didn't help.
Thanks for any imput!
Rick --
Submitted by dougdwyer1@com… on Sat, 01/09/2010 - 10:57
Submitted by SC38-21185J on Sat, 01/09/2010 - 09:18
CAN ANYONE SHED SOME LIGHT ON THIS PROBLEM?
Could be any number of things. I would change plugs, cap and rotor for starters, then fuel pump. Replace any in-line fuel filters. You might have a slug of bad gas? A good tune-up by a qualified mechanic might be in order. Look for any disconnected vacuum lines at the carbs and distributor.
Submitted by craftsman-styl… on Sun, 11/22/2009 - 08:18
Submitted by woodward_rick@… on Mon, 11/16/2009 - 14:18
It's a 1997 Jaguar XJ6.
Rick Woodward
Submitted by dougdwyer1@com… on Sun, 11/08/2009 - 15:43
What kind of Jag is it?
DD
Ignition coil failures are common on that model...but you'll have to figure out which one of the six to replace.
Also, 50 mph@steady throttle is right about where the torque converter would lock-up....which feels like another gear change. If the system was having difficulty deciding to lock-up or release it could bounce between the two and it might feel like a misfire.
I would advise getting a scan tool which can display live data so you can check for any trouble codes and monitor the engine management system while the problem is actually occuring.
DD
