I have a 1995 xj6, there is no heat comming out, the cold a/c seems to work ok, blower is fine too. I guess it might be a blocked heater core, I don't know where it's located or what it looks like, any ideas?,
Also I am replacing my fuel sender, do I need to use sealant? anything special about doing it?
Colin
Submitted by grahamdallen@aol.com on Tue, 04/12/2005 - 16:40
The heater is more than likley the servo motor stuck which is fitted on the right hand side of the heater box. Just try tapping it lightly while your set to hot on the controls. The tank sender is a rubber seal and best fitted dry with no sealer. Good luck.
