Joe,
With the exception of the two corroded and broken studs, all other studs were removed without a problem. The plan is to replace all studs with new ones when I'm ready to reinstall the head (which is currently at a local machine shop).
On another note, when/if I get this buttoned-up and running again, I may want to chat with you regarding removal of the emissions equipment.
Talk to you later & thanks again.
Dan
