Tony, heat the tube that the steel pin goes into. The tube will expand and release the pin. You might also try tapping against the aluminum hing with a wood block to drive out the pin. If you get too much heat the weld will melt at the tube connection. Keep the heat off the aluminum.
Good luck.
Cheers Tom
