John, jokes aside, your car should not leak, where is the leak from. When faced with this question I say there is a SEEP which rarely touches the ground;; a drip which makes a slow small mess and, a leak which we should not have! I then suggest they look at the engines on any prop car, tyhey all seep as The rotating shaft needs lubrication all the was through.
