It leaves no puddles, just goes through trans fluid, ideas?
Thanks!
Submitted by woebegone@mind… on Fri, 10/23/2009 - 23:17
The V-12's have an external transmission modulator valve, don't know if your version does or not.
When those go, the manifold vacuum sucks out fluid quite rapidly.
Generally on the back of the main body of the transmission, right side, just above tha pan.
If you have one, engine off, pull the rubber hose (don't have your face in front of it), and see.
Usually, if you are using that much, it will have quite a bit in the hose and pipe.
