Cars temp gauge gets to the middle (90) Air cond works, heater blows but the amount of heat is nothing. It takes 10 minutes to get 'cool' and it NEVER gets hot inside. I've tried auto/manual. I keep the heater on full heat, face vents full, and i've tried econ and no lights for the compressor. I've tried leaving it on defrost, full vents, med, low. Nothing gets me heat, its like its someone that lets the air get heated then gets blown inside is getting stuck?
thanks in advance.
Submitted by hispeed42@aol.com on Tue, 04/01/2003 - 08:04
I would try a new heater control valve. If it's not that, you may have a control unit problem. Mine had low heat output, but I suspected the thermostat, as the temp gauge would not get above 1/3rd during cold weather.
Mark D. Washam
98 XJR
