The switch for the right rear window on the console had quit working sometime ago,but I could still operate the window with the switch at the back of the console that is for rear seat passengers.Yesterday I put the windows down,had to raise them briefly,and the right rear would only go up,reversing the switch had no effect..With the A/C inoperable at this point having all four windows down is a must!Any suggestions greatly appreciated.
Submitted by dougdwyer1@com… on Sun, 06/08/2008 - 08:46
Quite often its simply a matter of dirty contacts inside the switch. The switch can be removed, gently disassembled, and the contacts cleaned with a pencil eraser.
DD
