Well it's down to the removal of the torsion plate then I can drop engine/trans.I thought driver side access to torsion nuts was difficult;finally got those free.Are there any tricks to gaining access to passenger side nuts.Access to slave cylinder upper nut also a problem.Is there any harm in wedging trans/bellhousing over a bit to gain access to remove slave cylinder which would then provide better access to torsion nuts?
