Working on a late model '59 150 and trying to set solenoid adjustment. i believe the actuating shaft arm is not positioned correctly in the case and need some verification. When setting the arm with the 3/16 pin, I have to rotate the shaft counterclockwise at the setting arm to engage. I think it should be rotating clockwise to set. Is this correct?
