I cant get my left ft turn signal to work, replaced the bulb twice, checked the connections, checked the socket all seems ok, could it be a fuse? and where would it be located, this is the only thing that doesn't work and it is driving me crazy, I thought that maybe some one could help me before I have to take it in. thanks jim
Submitted by stevejag@sbcgl… on Tue, 09/09/2014 - 12:12
Do the LH lights flash OK with the flashers turned on?? That will confirm they are capable of working. If they work do work, suspect a problem with the direction indicator/headlamp switch itself, or possibly a broken wire in the harness that goes up the steering column. Right and Left signals each have a circuit from the switch to the Body Processor. If one circuit breaks, you lose one side turn signal.
Good luck!
