I am trying to replace the headlight bulbs for 1995 XJS. I have removed the meta; clips from the headlight cover but I cannot separate the headlight cover from the base. Is there a special tool to remove the headlight cover or does the headlight cover just get difficult to remove over time?
Submitted by jh3478@roadrun… on Mon, 02/05/2007 - 19:42
Submitted by mghirsch@netzero.net on Sun, 02/04/2007 - 19:00
1995 XJS Headlight Replacement
MIf it like my 94, look in the wheel well. You will find an acess panel held on by two thumb screws. Undo them, the panel comes off and reach in and replace the bulb.
Maynard Hirsch
86 XJ6
91XJS (RIP)
78MGB
67MGB
Mr. Hirsch is correct; on my 1995 xjs the owner's manual says to turn the front wheels in or outward to give access room; then, there is a panel behind the headlights inside the wheel well to remove to access the bulbs.
