Before I get in too far with cut fingers and unreachable parts, can I remove the fan shroud without disconnecting the radiator? It looks as if it is possible to undo the 4 bolts holding the fan and clutch to the water pump, is there enough clearance then to extract the fan and the clutch and lift the shroud out? I can't find instructions anywhere. Thanks.
