I just bought my XJS and when I put the top up the passenger side rear window did not go up. I have seen others with the back windows down is this a common problem and how can I fix it.
Submitted by SE98-32482CJ on Mon, 08/08/2005 - 06:16
First check the relay in the storage area behind the seats. If this is ok try banging the motor with a long rod. You may have to remove the cover first (several screw). Good luck. George Camp
Submitted by BBAITLON@socal… on Mon, 08/08/2005 - 01:30
