Has anyone had a problem with Jag stalling or dying in extrmemely cold weather....what could cause this problem....oil pressure reads high...but water temperature remains cold...starts fine, but stalls and dies out after 10-15 minutes of driving...low to no compression
Submitted by chapmanj@nwinfo.net on Wed, 12/14/2005 - 01:49
I have not had that trouble in cold weather, but one thing to check would be the top dead center (TDC) sensor on the crankshaft. Mine had a problem and would shut down unexpectedly. It's an easy fix if that's the problem, but it's not cold weather related. Mine would run and then suddenly just stop dead.
JD Chapman
1990 XJ-S Coupe
