looking for the location of the relay that tells the car it is in park so the car will start
Submitted by silver007@shaw.ca on Thu, 12/30/2010 - 15:44
Submitted by SE98-32482CJ on Thu, 12/30/2010 - 14:30
1989 xjs v12 location of relay
Bob super!!!!! Bob are you in JCNA? If not why not join--think of it this way--we just saved you at least 3 times what a JCNA membership would have cost if you took the car to a shop! If already a member how about editing your profile so we know where you are--have a happy New Year!
Submitted by crhorneff@aol.com on Thu, 12/30/2010 - 14:02
fixed the problem the switches were sticking they are in the front of the lever i want to thank you for all the advice the kitty is once purring thanks to all that help me
Submitted by SE98-32482CJ on Tue, 12/28/2010 - 17:31
Bob you have to take off the "ski slope" or the covering to the center but you do not have to take off the entire center console.
Submitted by silver007@shaw.ca on Tue, 12/28/2010 - 16:58
Hi Bob,
hope you got it off okay and found the faulty switch, if you ever get a chance to try a 6.0.do it.....Art
Submitted by crhorneff@aol.com on Tue, 12/28/2010 - 15:33
do i have to take out the center console in order to get to these micro switches or is there a easier way to get them and if i do have remove the center console what is the best way to do it thanks for the infor you guys have really helped me alot
Submitted by bonnettoboot@e… on Tue, 12/21/2010 - 00:04
Yes, sorry for the confusion, it is at the front left of the gear lever, there are two micro switches together, the other is for the reverse lights.
Submitted by SE98-32482CJ on Mon, 12/20/2010 - 23:08
Doug that is the way I read it--but I think it is on the front of the selector--2 micro switches--right?
Submitted by dougdwyer1@com… on Mon, 12/20/2010 - 22:52
William, it dawns on me that when you said "....on the left side of the gearbox" that perhaps you meant left side of the gearshift (??)
DD
Submitted by dougdwyer1@com… on Mon, 12/20/2010 - 22:49
William, no, not on the side of the trans, not on a XJS V12 with the TH400 trans. Perhaps you're thinking of a Ser III Xj6 with the BW66 trans?
The safety switch in thise case is at the gearshift quardrant.
DD
Submitted by SE98-32482CJ on Mon, 12/20/2010 - 22:24
Bob William is right and spilt coffee usually does the trick. If your car will not start in neutral either then suspect the starter relay (RH side of the engine bay toward the cabin under a black plastic cover). Also check the red/ white starter sol wire at the connection in the middle of the engine at the rear for crud--just follow the wire from the relay and you will find it! Good luck.
Submitted by bonnettoboot@e… on Mon, 12/20/2010 - 21:53
It isn't a relay Bob it is a switch on the left side of the gearbox. Hold the ignition switch in the start position and apply the brakes, now move the gearlever through the range and see if there is a position where it starts, if yes the switch needs adjustment, if not, the switch is likely bad.
JCNA is a good organization to belong to, does not cost a lot but offers a lot in return.......I joined a local affiliate soon after I bought my Silver XJS GT ................... That was 20 years ago or more.......... we bought thew car when our son Chase was 1 year old.......... he has been with me to many JCNA events and now has his own X Type which he has shown and slalom raced at many JCNA events on the West Coast... Has also won a few North American Championships in doing so... and basically kept him out of trouble............ and thats not easy these days..........
