I am looking for a very good condition or rebuilt short block. Any ideas or good sources? Top end and all accessories are rebuilt or new. Down low we have a bit of a knock.
![](https://www.jcna.com/sites/default/files/20180518_074537.jpg)
Submitted by Michael D. Rogers on Sat, 02/08/2020 - 19:04
You probably have solved this by now, if not, hopefully you've pulled the pan, bearing caps and miked the crank. a bearing may just have too much clearance due to wear and if the journal is still within specification a new bearing shell will solve the noise.
