1983 XJ6 With Borge Warner Auto Trans. What type Transmission fluid should I use?
Submitted by cmxserv@mybizz.net on Sat, 12/14/2002 - 10:00
Submitted by greg@coventryw… on Tue, 11/19/2002 - 12:42
Re.: 1983 XJ6 with Borge Warner Auto Trans .What type Trans fluid
This car used Type F trans fluid, sometimes labled as Type FA, Type G, and who knows what else.
Old timers will know this as Ford type fluid, used before the GM fluid (Dexron) and Ford ATF sort of merged into Dexron/Mercon. Nowdays GM and Fords all use Dexron/Mercon. Just don't let some counter jockey convince you that Dexron/Mercon is what you want if you're seeking Type F.
Since few cars use this type of ATF any more, it can be hard to find. Here in the Atlanta area, it is available from NAPA stores, labeled as Type FA.
It is worth noting that the difference between Dexron and Ford type fluids has to do with the friction coefficient. Some Jaguar owners use Dexron in their SIII cars and claim it gives softer shifts IIRC.
But the Ford ATF is what Jaguar recommended (usually listed in the specs as Type G BTW).
Gregory Wells 800-331-2193 x103
Coventry West, Inc.
www.coventrywest.com
Walmart carries Quaker State type F Trans fluid.
