I have a 1966 3.8 S with a starter tand spins but does nit engage the flywheel. What is the procedure to remove said starter?
Submitted by SE98-32482CJ on Tue, 08/31/2010 - 17:41
Submitted by grussell@thurs… on Tue, 08/31/2010 - 13:12
1966 3.8 S starter remaval
George
Thank you for the helpful information. The starter bolts do have that half moon wire conecting the studs. Those are the only bolts (2) holding the starter?
Glenn
Submitted by SE98-32482CJ on Tue, 08/31/2010 - 12:46
Glenn--disconnect battery. Check the inner trans cover to see if you have a starter access panel--if so remove it and unbolt the two starter bolts--or you may have two bolts on a simi circle wire (much easier) remove the cable to the starter and remove--you may need to remove the oil pressure sender to slide it forward. Good luck.
Yes--plus the elec. lead.
