I am in desperate need of your help. My car is for sale and I wanted to make sure that everything is
fine when I hand over the keys. Mechanicals are all sorted out. Changed the oil and thought that I should flush
the hydraulics.Brakes went fine with the handy dandy one man brake bleeder.Could not get the clutch system
to work. Thought it was just my luck that the master and/or slave decided to go out at this time.
Put new ones in and still can't the system to bleed properly. The lever in the slave is only moving about half in inch so the
clutch is not disengaging. Help! I've tried it with the front end up in the air and I've tried it level and have also
bled it the old fashioned down/up way. Frustrated.
Submitted by coventryclassi… on Mon, 11/25/2013 - 15:00
Ronald, there were two or three different slave cylinders. Measure your old one & see if you got the correct replacement. Good Luck.
Cheers Tom
